I am new to Ubuntu. I have a DINOSAUR machine that was not being used, and thought it would be a learning experience to wipe it clean and try a Linux-based OS.
14.04 LTS was installed on a completely clean hard drive (DoD wipe specifications). Ubuntu OS boots just fine, but ALL operations are extremely slow to react to user inputs.
Computer specs:
  • 14.04 LTS 32-bit OS;
  • 512MB (495.2 MiB reporting) PC2700 DDR 333MHz RAM;
  • IntelĀ® Pentium(R) 4 CPU 2.40GHz;
  • VGA Video: Radeon 9000
  • Series R200 (RV250 4966) x86/MMX/SSE2 TCL DRI2;
  • 60 GB Hard Drive (58.4 GB reporting);
  • 8PE667U Gigabyte Motherboard, BIOS: Award v6 Oct2002
Thus far, only diagnostic action was to generate 'system.html' with a report of all components. Some of the blocks are highlighted in red, but I am not experienced enough to interpret the results and take corrective action. Is there a way to share the file with this community to help expedite a potential solution?
Yup your Ram is the problem consider adding AT LEAST another 512mb...here are some other tips to speed things up! Since you have such little Ram I HIGHLY RECOMMEND USING XUBUNTU!
  1. Change Swap gksudo gedit /etc/sysctl.conf
ADD THIS ENTRY AT END AND SAVE
vm.swappiness=5
Remove bloatware https://fixubuntu.com/
wget -q -O - https://fixubuntu.com/fixubuntu.sh | bash
Get the following Tweak Tools Ubuntu Tweak ( sudo apt-get install ubuntu-tweak )
Tweak Tool ( sudo apt-get install gnome-tweak-tool )
Unity Tweak ( sudo apt-get install unity-tweak-tool )
Dconf Editor ( sudo apt-get install dconf-tools )
Compiz Config Editor ( sudo apt-get install compizconfig-settings-manager compiz-plugins-extra -y )
Review each section of each tool and modify as desired
Get Bleachbit I suggest downloading the newest version as the one in the repository(Software Center) is old. You can download it here: http://bleachbit.sourceforge.net/download/linux
Review the following sites and modify your system as needed. https://sites.google.com/site/easylinuxtipsproject/first#TOC-Decrease-the-swap-use-very-important-
https://sites.google.com/site/easylinuxtipsproject/speed
http://www.techsupportalert.com/content/best-free-software-linux.htm?page=0,0#Introduction
http://smashingweb.info/things-to-do-after-installing-ubuntu-14-04-lts-for-perfect-desktop/
http://ubuntuforums.org/showthread.php?t=140920
http://www.techsupportalert.com/content/tips-and-tricks-ubuntu-after-installation-ubuntu-1404.htm
Check FPS
Open terminal
type glxgears
hit enter
HOPE THIS INFO HELPS A BIT!
One other awesome tool I use is CPU Indicator
Open Terminal
Install
sudo apt-get install indicator-cpufreq
Run
'indicator-cpufreq' in terminal to launch
Reboot!!! You will see the icon in the top bar of unity interface. Right or left click icon and select the fastest cpu speed or desired speed! This tool is AWESOME and will help a TON!
