I downloaded Android NDK from https://developer.android.com/tools/sdk/ndk/index.html but I am not able to extract it.
If I double-click it I get an error:
Could not display “android-ndk-r10c-linux-x86_64.bin”. The file is of an unknown type
I have selected the option in permissions to "Allow executing file as program".
When I attempt to execute it with terminal (sudo ./android-ndk-r10c-linux-x86_64.bin) I get this error:
sudo: unable to execute ./android-ndk-r10c-linux-x86_64.bin: No such file or directory
I have 64 bit Ubuntu 14.10 running on VirtualBox. Any help would be appreciated.
R L
  • 101
Use 7z x *bin as workaround as all r10c packages are 7z archive. To install 7z, do sudo apt-get install p7zip-full.
Found that from here: https://code.google.com/p/android/issues/detail?id=78148
Eliah Kagan
  • 119,640
R L
  • 101
Running
7z x android-ndk-r10c-linux-x86_64.bin
will extract the ndk.
Eliah Kagan
  • 119,640
kakopappa
  • 121
Android's NDK now ships as an self extracting executable. You likely need to set the executable bit, however:
$ chmod +x android-ndk-r10c-linux-x86_64.bin $ ./android-ndk-r10c-linux-x86_64.bin
