-1
Unity 14.04 is failing to load after an upgrade from 12.04. I think it is because it was an incomplete upgrade and there was some errors. I finally got it to recognize me and let me login into Unity with my user name and password but then it crashes. When I went into the terminal I searched for errors but have no clue what the below code describes:
X Error of failed request: Bad Request (invalid request code or no such operation)
major opcode of failed request: 155 (glx)
minor opcode of failed request: 19 (X_GLXqueryserverstring)
serial number of failed request: 22
Current serial number in output stream: 22
openConnection: connect: no such file or directory
cannot connect to brltty at: 0
script for ibus started at run_im.
script for auto started at run_im.
script for default started at run_im.
init: update-notifier-crash (/var/crash/_usr_lib_i386-linux-gnu_libgtk-3-0_gtk-update-icon-cache-3.0.0.crash) main process (2007) terminated with status 1
init: update-notifier-crash (/var/crash/_usr_sbin_unity-greety.114.crash) main process (2008) terminated with status 1
A.B.
  • 92,125
As you have a serious problem, and you're a new user and you're probably panicking right now, I'm cutting you some slack to tell you to:
  1. Press Ctrl+Alt+F1
  2. Log in on the console (the big black screen you just arrived to)
  3. Point you to: How to reinstall Unity
Fabby
  • 35,017
