I am aware why linux doesn't mount the hibernated windows system partition -- due to the hibernation flag. As far as I am aware, the hiberfil.sys is stored on windows system partition, then why does it prevent linux from mounting a different partition?
I have 4 partitions:
  • Lubuntu
  • Windows
  • Windows backup
  • DATA (file storage)
Basically, I couldn't care less for the windows system partition, I don't even mount it on linux. All I care about is sharing my files on both windows and linux through the DATA partition. Is there a way to achieve this while retaining the possibility of hibernating windows?
I found a solution to my question on my own.
SOLUTION
Wrote in terminal:
sudo ntfsfix /dev/sdXY
where sdXY is the partition I needed to mount, in my case - DATA partition. With this I can hibernate windows and still be able to use the DATA partition on lubuntu without losing the hibernated data on windows, which is on windows system partition.
-1
The short answer to the question: "why lubuntu is prevented to mount a partition on which the hiberfil.sys is not present?":
Making changes to your Windows (ntfs) partition while it is hibernated could be dangerous--it could cause Windows to not resume from hibernation or to crash after resuming.
I only quoted this from the much more detailed answer https://askubuntu.com/a/145904/865596. (But I think this is correct because it sounds very reasonable and it got many upvotes)
Some people (with reputation 20 000+) say that writing on a hibernation flagged NTFS partition (for example by using code like "sudo ntfsfix /dev/sdXY") can result in data loss on the NTFS data partition. (see answers of Unable to load Windows(8.x) Partition in Ubuntu or in the comments of https://askubuntu.com/a/532753/865596 or https://ubuntuforums.org/showthread.php?t=2364784)
In https://askubuntu.com/a/532753/865596 people say that the solution https://askubuntu.com/a/552232/865596 can be very dangerous (see explanation in https://askubuntu.com/a/145904/865596).
I think https://askubuntu.com/a/145904/865596, https://askubuntu.com/a/843161/865596 and maybe https://askubuntu.com/a/843373/865596 might be safer solutions, but I am not an expert. I got to these solutions from https://ubuntuforums.org/showthread.php?t=2364784&s=6b0a085ceec98b88abc61f5d1e97ae5e&p=13660216#post13660216
This question might be related to my question Is dual-boot Windows 10 with hibernation and Ubunutu 18.04 dangerous? too.
Jakob
  • 121
