11
I have a small issue with my Ubuntu (I think After an upgarde). When I try to login (Login Screen), I get disconnected and get back to the screen (again & again).
I tried:
  • Trying to login with others Desktop environements.
  • Booting from old kernel.
  • log in via command line [apt-get update && apt-get upgrade].
  • removing ~/.gconf directory.
  • sudo apt-get install --reinstall ubuntu-desktop and sudo apt-get install unity
None of these solutions worked.
Zanna
  • 72,312
Jesus
  • 113
Press Ctrl+Alt+F3 and login into the shell using your username and your password. In this case username will be your username you set when you installed Ubuntu.
Now run ls -lah and look for the output line that ends with .Xauthority
-rw-------  1 root root   53 Nov 29 10:19 .Xauthority
then you need to do chown username:username .Xauthority and try logging in.
Else, do ls -ld /tmp. Check for the first 10 letters in the left: they should read exactly so: drwxrwxrwt.
drwxrwxrwt 15 root root 4096 Nov 30 04:17 /tmp
Else, you need to do sudo chmod a+wt /tmp and check again.
If not both, I'd recommend you either
Make sure you are connected to internet with DHCP on.
  1. sudo apt-get purge lightdm
  2. sudo apt-get update
  3. sudo apt-get install lightdm
  4. dpkg-reconfigure lightdm
Now type sudo shutdown -r now to restart.
MeSo2
  • 451
Alex Jones
  • 8,192
