I have a problem that Geary is not installing even after repeated attempts. The below is the error I am getting. Please let me know what is the corrective measures Thanks!
Reading package lists... Done
Building dependency tree
 geary : Depends: libgee-0.8-2 (>= 0.14.0) but 0.10.5-1ubuntu1 is to be installed
Shash
  • 1,061
  • 15
  • 27
Install following ppa: https://launchpad.net/~vala-team/+archive/ubuntu/ppa
using:
sudo add-apt-repository ppa:vala-team/ppa
then perform an update and upgrade
sudo apt-get update
sudo apt-get upgrade
after that, just install geary (from the daily ppa)
sudo apt-get install geary
