When I want to install with this command sudo dpkg -i linux-image-3.14.24-031424-generic_3.14.24-031424.201411141736_amd64.deb I got follow error:
grub-probe: error: unknown filesystem.
run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.14.24-031424-generic.postinst line 1025.
dpkg: error processing package linux-image-3.14.24-031424-generic (--install):
 subprocess installed post-installation script returned error exit status 2
After restart I got this error:
Initialize variable space ...
Starting cmain() ... (hd0,0)
[Multibot-kludge, loaddaddr=0x100000, text-adn-data=0x6315, bss=0x0, entry=0x100990]
Entering rescue mode...
grab rescue>
How can I boot again? Pleas help me!!
UPDATE 1
This file is result of boot-repair package: http://paste.ubuntu.com/9143905/ http://textuploader.com/ow4p
UPDATE 2
When I want to purge previous grub and install new one with boot-repair in live cd, got this error:
Installing for i386-pc platform.
grub-install: error: unknown filesystem.
UPDATE 3
When I run this command: sudo grub-install --root-directory=/mnt /dev/sda I got this output: sudo grub-install --root-directory=/mnt /dev/sda
you can use boot repair burn it as image on cd and leave it . it will repair every thing. http://sourceforge.net/projects/boot-repair-cd/ after that u can boot ubuntu again.
amr
here are some methods that will help you to recover system if kernel is remove by mistake
  1. https://askubuntu.com/a/28100/294611
  2. https://askubuntu.com/a/46696/294611
  3. https://askubuntu.com/a/100953/294611
all three answers above are different ways to do the same thing, try atleast one(since all are same). First read all the answers then try the method you understand.
Alex Jones
  • 8,192
