$ /opt/jboss-as-7.1.1.Final/bin/standalone.sh
JBoss Bootstrap Environment
JBOSS_HOME: /opt/jboss-as-7.1.1.Final
JAVA: /usr/lib/jvm/jdk1.6.0_32/bin/java
JAVA_OPTS: -server -Xms64m -Xmx512m -XX:MaxPermSize=256m -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml
/opt/jboss-as-7.1.1.Final/bin/standalone.sh: 1: eval: /usr/lib/jvm/jdk1.6.0_32/bin/java: not found
Asked
Active
Viewed 3,790 times
astrob0t
- 1,766
A Java 6 installation on your computer was not found in its default place, you should install Java 6 from the Software center or grab the package. If you already have a Java 6 installation, you should make sure it's installed in the right path, is up to date, and is the right version for your program.
All the program is trying to do is run a Java application using that specific Java version: 1.6.0_32. Simply install it the default way and you should be good to go.
Robobenklein
- 1,496
