So here is a summary of what I have been doing today.
  1. Dual booted a laptop (windows 7 64 bit home & ubuntu 14.04); diferent partitions + a data partition.
  2. had to install grub manually (done right)
  3. decided to go back to windows(ubuntu was not for my technologically challenged father)
  4. The MAJOR hiccup: deleted the partition with Ubuntu=> no bootloader
  5. tried reinstalling ubuntu to get grub working again.(failed)
  6. Managed to get a windows repair disk and fixed that
  7. So NOW I realised that the ubuntu installation was done in the data partition.
    windows cannot see the ubuntu partition or the missing data.
I only have a free version of minitool right now, and I realise that I am more of a noob than I thought.
Can anyone please help me recover at least part of the data?
Nirvan
First of all if you had all your data in your Ubuntu partition (as I understood) , you said that you formatted it.
Secondly , you noticed that Ubuntu installed in your DATA partition (which formatted all your data in DATA partition). So as I understand you did both the Ubuntu and DATA partitions format.
Thirdly you don't see DATA partition because when you installed Ubuntu probably it changed the type from NTFS to EXT4(or if you have chosen EXT3 or etc.) which Windows won't see by default
Check this http://www.howtogeek.com/112888/3-ways-to-access-your-linux-partitions-from-windows/
So if you want recover your data you could try data recovery tools on Windows maybe it will recover some...
Dambre
  • 166
