my ubuntu is 14.04. I need to install numpy 1.8.1. Where can I find its directory?
You can install it with sudo apt-get install python-numpy. The version in 14.04 is 1.8.2 (it was updated from 1.8.1 --- so probably you want to stick with the new one; it's a stable release update so it surely fixes bugs).
If you want to stick with the older version due to a verification script (which is not recommended; that script is not very well thought) you can do that; install it with the suggestion here: How to Downgrade a Package via apt-get? and then mark it "held" with apt mark hold python-numpy. Basically it should be (not tested)
sudo apt-get install python-numpy=1:1.8.1-1ubuntu1
sudo apt-mark hold python-numpy
...but I would fix the script instead. Holding packages can have a lot of nasty consequences on the long run.
The available versions can be found with apt-cache search numpy and after finding the correct name (by looking at the list):
[romano:~] % apt-cache policy python-numpy
python-numpy:
Installed: 1:1.8.2-0ubuntu0.1
Candidate: 1:1.8.2-0ubuntu0.1
Version table:
*** 1:1.8.2-0ubuntu0.1 0
500 http://archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
100 /var/lib/dpkg/status
1:1.8.1-1ubuntu1 0
500 http://archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
