Possible Duplicate:
phpmyadmin is not working after I installed it
I have ubuntu 11.04.
I installed lamp
So i automatically got things like mysql , php , apcahe which are needed for it.
It also shows that the phpmyadmin package is installed.
But when i go to this : http://localhost/phpmyadmin
It shows page not found ?
There is also a user named phpmyadmin there already.
How can i open to the phpmyadmin ?
Thanks!!
kritya
  • 143
This is not a real answer to your question, but after the complication of setup and its slowness, I decided to use adminer: just one file, a lot of feature, more speed and no installation required: http://www.adminer.org . I suggest it to you.
fain182
  • 646
How did you install PHPMyAdmin? Did you use apt-get/the Ubuntu packages or did you grab the source from the PHPMA website?
https://help.ubuntu.com/community/phpMyAdmin seems a little out of date, but that should help you get it working. If you installed it using the package manager, I've always found it easier just to do it from source downloaded from the PHPMA website. You just download, unzip it and copy it into your /var/www or wherever your Apache root is.
David Futcher
  • 663
