-1
I was bored with my bootloader, .. Can I change the theme of the bootloader, .. I was looking on google, and I found the burg,. but I could not use it because my pc is UEFI, .. I dual boot windows8.1 and ubuntu14.10
rafly
You could try installing xubuntu or kubuntu by enter in the terminal:
 sudo apt-get install xubuntu
or
 sudo apt-get install kde-full
and it has two difference of boot loader theme, and those look better, and it works fine whit my pc this way.
Michael
  • 2,597
Since you were "bored" as per your question, I am not sure if the below will actually "entertain" you enough or not but if you do not get fooled by the "GRUB2" title in the link am giving, then yeah, you can customize your GRUB Bootloader menu screen to your taste.
http://members.iinet.net/~herman546/p20/GRUB2%20Splashimages.html
Most of the instructions will work for GRUB as well. And do not forget to run grub-mkconfig after making the changes :)
Horizon
  • 281
