after running the installation of the driver i get an error that i need to install some prerequisites found in the fglrx-install.log file and there i found this
NOTE: If your system has logged the missing packages required for installation, install them in the order as per the log file to resolve package-dependency issues.
Package dh-modaliases is missing from the system. Install it using the command apt-get install dh-modaliases.
Package execstack is missing from the system. Install it using the command apt-get install execstack.
Package dpkg-dev is missing from the system. Install it using the command apt-get install dpkg-dev.
Package debhelper is missing from the system. Install it using the command apt-get install debhelper.
And I installed everything without problem except debhelper, it gives me this error
Reading package lists... Done
Building dependency tree
 debhelper : Depends: dpkg-dev (>= 1.17.0) but it is not going to be installed
Wilf
  • 30,732
