I use alt-shift to switch between keyboard layouts in Ubuntu 14.04. I have 3 languages enabled, but I use one of them much less often.
How could I make alt-shift skip the rarely used language(s)?
Valentas
  • 1,138
This is what "switch to previous layout" should do but it does not on Ubuntu. It just doesn't work.
It does work great in OSX. It loops through the layouts you 've used lately(usually two).
DimiDak
  • 741
I would assume you can not. The system does not count keyboard lay-outs used to determine how often it is used.
Then again it becomes possible if you change the question to ....
How could I skip the rarely used language(s)?
Then the answer would be: by using another key combination and change that key combination to switch between the 2 lay-outs you do want to switch between.
Lay-outs are numbered from 0. So the 1st and 2nd lay-out are activated with respectively...
$ gsettings set org.gnome.desktop.input-sources current 0
$ gsettings set org.gnome.desktop.input-sources current 1
(or "2" if you, in your case, need the 3rd keyboard).
This will take up 2 keys though: you can add one to a key like control + P and the other to control + O. If you want this to be one key you would need to change the 0 in
to a variable that toggles the 0 to a 1 and a 1 to a 0.
That would be this command:
gsettings set org.gnome.desktop.input-sources current $(($(gsettings get org.gnome.desktop.input-sources sources | grep -Po "'[[:alpha:]]+'\)" | wc -l)-1))
This would allow you to use 1 key and make it a toggle.
Refer to How can I change what keys on my keyboard do? (How can I create custom keyboard commands/shortcuts?) on how to set this. Tweak tools and compiz action plugin would be 2 methods on setting those.
Rinzwind
  • 309,379
