I am trying to install a secondary OS (OpenSUSE) onto another partition while keeping Trusty. I tried to do it via USB about 7 times now (using unetbootin, some other program that required a repository, and I've tried universal-usb-installer and 7z. All options give me the exact same error "No Repository Found" so the flash drive easily boots the installer but the installer cannot find the os. How can I install the Suse installer onto another partition or install it directly? I know this question isn't based on Ubuntu but /superuser and /unix didn't help and I still have some hope to the much larger community here. Is there an ubuntu program that can install Suse kinda like wubi.exe?
First off, you want to create a partition for SUSE. Boot into an Ubuntu LiveCD and use GParted. Make it ext2/3/4. Once you are done with that, reboot.
Back in Ubuntu, download the SUSE iso. Run this command as root (su) in a terminal:
dd if=/path/to/downloaded.iso of=/dev/sdX bs=4M
Replace sdX with the appropriate device identifier for the USB drive. You can usually find this using lsblk. Do not write to a partition on the drive. Write to the drive itself.
Reboot into the USB drive and follow the instructions. When asked where to install SUSE, choose the partition you made earlier.
Once you are done, you will need to re-install Ubuntu's Grub. Details on how to do that are right here.
Disclaimer: I am not responsible for anything that goes wrong in this answer. By using this answer, you agree that any errors from using this question is not my fault.
Test this:
Download image.iso, openSUSE-13.2-DVD-x86_64.iso, suppose in /home/nick/Download
http://software.opensuse.org/132/en
Open a terminal CtrlAltT.
And run:
sudo -i
mv /home/nick/Download/openSUSE-13.2-DVD-x86_64.iso /
gparted
Make you an ext4 partition for /.
/home with different username,and /swap, it can be shared.
Apply the changes and edit /etc/grub.d/40_custom file
nano /etc/grub.d/40_custom
In the file put this content
menuentry "openSUSE 13.2 DVD" {
set isofile=/openSUSE-13.2-DVD-x86_64.iso
set root=(hd0,1)
loopback loop $isofile
linux (loop)/boot/x86_64/loader/linux install=hd:$isofile
initrd (loop)/boot/x86_64/loader/initrd
The root=(hd0,1) is the ubuntu / partition your iso image on.
hd0,1 = /dev/sda1
hd0,2 = /dev/sda2
hd1,1 = /dev/sdb1
hd1,2 = /dev/sdb2
The isofile is the path to your iso file. It's located on the root of /dev/sda1.
Let's say you have a separate home partition and your iso is at /home/nick/Dowmload/openSUSE-13.2-DVD-x86_64.iso. You would need to change it to:
isofile=/nick/Download/openSUSE-13.2-DVD-x86_64.iso.
Change the x86_64 to i386 if you're using 32 bit.
Ctrl + O, save file. Ctrl + X, close nano.
You need to update grub2 to recognize your new menu entry.
update-grub
Now you can reboot and select the new entry from Grub2.
The DVD will boot up and work just like normal.
The Grub should be installed on the partition / of openSUSE
Upon restart, Ubuntu only appear in the menu, to:
sudo -i
update-grub
The menu will join the openSUSE installed.
- 17,808
