I'm using Ubuntu 14.04 LTS on my Acer Aspire 4830TG. I can't activate Bluetooth. I have no Icon in the top bar (the check box in the settings does nothing) and when I click activate in the settings nothing happens. Any idea how I get it to work?
Daniel
You might want to try a newer kernel, as suggested in this answer to a similar question: ASUS Z87 Pro Bluetooth not finding other devices with 13.10
Here are instructions to upgrade your kernel: How can I install 3.16 kernel on Ubuntu 14.04
General Instructions To Install A New Kernel
The latest kernel available for Ubuntu 14.04 Trusty is 3.14.1. The files can be downloaded at: http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.1-trusty/
The latest kernel available for Ubuntu 14.10 Utopic is 3.17.1. The files can be downloaded at: http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.17.1-utopic/
Other kernel versions can be downloaded from: http://kernel.ubuntu.com/~kernel-ppa/mainline/
You would need to download three files:
  1. linux-headers-*-generic_[i386|amd64].deb
  2. linux-headers-*_all.deb
  3. linux-image-*-generic_[i386|amd64].deb
Note: Replace "[i386|amd64]" with "amd64" if you need the 64 bit kernel, or with "i386" if you need the 32 bit kernel.
After downloading, you can double click on the *.deb files to install them. However, you can also use the simple command line steps below.
Specific Instructions To Install A New Kernel (3.14.1 or 3.17.1)
Note: I've included instructions for kernel 3.14.1, but for me, bluetooth did not work with this kernel. Bluetooth did work with kernel 3.17.1, available for Utopic. Which kernel works really depends on whether or not the kernel you install has support for your bluetooth hardware adapter. There is an issue with the bcmwl wireless drivers in kernel 3.17.1, and I've included a fix for that as well.
cd ~/Downloads
mkdir kernel
cd kernel
Only execute the next three lines to download the 64 bit kernel version 3.17.1.
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.17.1-utopic/linux-headers-3.17.1-031701-generic_3.17.1-031701.201410150735_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.17.1-utopic/linux-headers-3.17.1-031701_3.17.1-031701.201410150735_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.17.1-utopic/linux-image-3.17.1-031701-generic_3.17.1-031701.201410150735_amd64.deb
Only execute the next three lines to download the 32 bit kernel version 3.17.1.
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.17.1-utopic/linux-headers-3.17.1-031701-generic_3.17.1-031701.201410150735_i386.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.17.1-utopic/linux-image-3.17.1-031701-generic_3.17.1-031701.201410150735_i386.deb
Only execute the next three lines to download the 64 bit kernel version 3.14.1.
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.1-trusty/linux-headers-3.14.1-031401-generic_3.14.1-031401.201404141220_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.1-trusty/linux-headers-3.14.1-031401_3.14.1-031401.201404141220_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.1-trusty/linux-image-3.14.1-031401-generic_3.14.1-031401.201404141220_amd64.deb
Only execute the next three lines to download the 32 bit kernel version 3.14.1.
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.1-trusty/linux-headers-3.14.1-031401-generic_3.14.1-031401.201404141220_i386.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.14.1-trusty/linux-image-3.14.1-031401-generic_3.14.1-031401.201404141220_i386.deb
List downloaded files *.deb files.
ls -la
List installed kernels, before installation of new kernel.
dpkg --list | grep linux-image
Install new downloaded kernel.
sudo dpkg --install *.deb
List installed kernels, including new kernels.
Reboot your computer so it loads the new kernel.
Verify that you are now using the newly installed kernel.
uname -r
Optional Fix For "bcmwl kernel module failed to build" Error in Kernel 3.17.1
If you install kernel 3.17.1 and are using using the bcmwl wireless driver, you may get a "bcmwl kernel module failed to build" error. See Launchpad Bug # 1358966 for more information.
Only execute the next line to fix bug 1358966 for kernel version 3.17.1, 64 bit.
wget https://launchpad.net/ubuntu/+source/bcmwl/6.30.223.248+bdcom-0ubuntu2/+build/6555554/+files/bcmwl-kernel-source_6.30.223.248%2Bbdcom-0ubuntu2_amd64.deb
Only execute the next line to fix bug 1358966 for kernel version 3.17.1, 32 bit.
wget https://launchpad.net/ubuntu/+source/bcmwl/6.30.223.248+bdcom-0ubuntu2/+build/6555555/+files/bcmwl-kernel-source_6.30.223.248%2Bbdcom-0ubuntu2_i386.deb
Remove the old bcmwl driver.
sudo apt-get remove bcmwl-kernel-source
Install the new bcmwl driver.
sudo dpkg --install bcmwl-kernel-source_*.deb
Reboot.
Note, you might have to delete your existing wireless connections and recreate them.
Uninstall New Kernel
Here are instructions to remove the new kernel, if you need to.
List installed kernels, before removal of new kernel.
Only execute the next line to remove kernel version 3.14.1.
sudo apt-get remove linux-image-3.14.1* linux-headers-3.14.1*
Only execute the next line to remove kernel version 3.17.1.
sudo apt-get remove linux-image-3.14.1* linux-headers-3.17.1*
Update initramfs ("Initial Ram File System").
sudo update-initramfs -u
List installed kernels, after removal of the new kernel.
Get A New Kernel As An Official Upgrade
If you are willing to wait, note that a newer kernel will be released in February 2015 for Trusty 14.04.2, as per this answer:
When will kernel 3.14 be available in the repositories?
Enterprise
  • 12,792
