I'm trying to use smbtree to view samba shares on my local network. Several of those shares are hosted on my own server, which I am running all these commands on. I know the shares exist because I can connect to them on my Mac using the "Connect to Server" (Cmd + K) command and entering
smb://name_of_my_samba_server
However, when I run smbtree, I can see other samba shares on the network but not my own. When I run smbtree with the -d3 option the only line of output that has anything to do with my own samba share and the the server it resides on is the following:
added interface eth0 ip=my.ip.address bcast=first.three.octets.of.my.ip.255 netmask=255.255.248.0
My smb.conf file is at the end of this post, but I don't think my problem comes from the configuration file because I have access to the smb.conf of someone running one of the servers that does appear when I run smbtree, and when I used that person's smb.conf as my own my samba shares STILL did not appear. I want to use smbtree because I'm trying to programmatically scrape the metadata for the samba shares on my LAN, and I'm trying to use smbtree to display all of the shares on the network.
EDIT: So I am able to see the shares on my server when I run
smbclient -L my_ip_address
but this still doesn't show up using smbtree. Why would the two programs (smbtree and smbclient) differentiate who they can see?
[global]
# Network Related Options
# interfaces to bind to
interfaces = lo eth0
# network segments to allow connections from
hosts allow = 127., 134.173.
# socket / performance options (generally, don't touch these)
socket options = TCP_NODELAY SO_RCVBUF=131072 SO_SNDBUF=131072
aio read size = 16384
aio write size = 16384
use sendfile = true
# Logging Options
# logs split per machine
log file = /var/log/samba/log.%m
# max 1024KB per log file, then rotate
max log size = 1024
log level = 2
debug timestamp= yes
# Authentication Options
# generally, don't touch any of this.
security = user
encrypt passwords = yes
passdb backend = tdbsam
map to guest = Bad User
guest account = nobody
# Filesystem Options
# These options correspond to windows file attributes that don't have
# UNIX equivalents. Instead of ignoring them, we emulate ('map') them.
map archive = yes
map hidden = yes
map read only = yes
map system = yes
store dos attributes = yes
# Nice Global Options
# makes UNIX dot files look like Windows 'hidden' files.
hide dot files = yes
unix extensions = no
# Miscelaneous Options
workgroup = MYGROUP
# no one actually uses wins
wins support = no
# this is just a simple file server, no printing
load printers = no
[Movies]
path = /home/alex/Movies
public = yes
browseable = yes
guest ok = yes
fake oplocks = yes
[Ebooks]
path = /home/alex/Ebooks
public = yes
browseable = yes
guest ok = yes
fake oplocks = yes
[Software]
path = /home/alex/Software
public = yes
browseable = yes
guest ok = yes
fake oplocks = yes
[Music]
path = /home/alex/Music
public = yes
browseable = yes
guest ok = yes
fake oplocks = yes
