I have created a deb package for an application created in Qt. I have included all the libraries that the application depends on, to be installed in a folder next to the application itself:
/usr/share/MyCompany/MyProduct/executable
/usr/share/MyCompany/MyProduct/Frameworks
Then exported LD_LIBRARY_PATH pointing to the Frameworks directory.
All perfect... Until I had to add QT Assistant, which requires additional libraries.
After checking the dependencies for Qt Assistant, I added all the required libraries, including libQtHelp.so.4 and libQtWebKit.so.4, in the same directory.
My deb is very simple, I create the structure desired then set the "install" to copy my files to the target directories.
blah_1/* /usr/share/MyCompany/MyProduct/
To create the package, I create the tar then
dh_make --copyright gpl -f ../blah-1.0.tar.gz
dpkg-buildpackage -rfakeroot -me@mycompany.com
When running the installer on a clean (no Qt) system, I am getting dependency errors:
me:~$ sudo dpkg -i /path/blah_1.0-1_i386.deb
Selecting previously unselected package blah.
(Reading database ... 141841 files and directories currently installed.)
Unpacking blah (from .../blah_1.0-1_i386.deb) ...
dpkg: dependency problems prevent configuration of blah:
 blah depends on libqt4-help (>= 4:4.8.0); however:
  Package libqt4-help is not installed.
 blah depends on libqtwebkit4 (>= 2.2~2011week36); however:
  Package libqtwebkit4 is not installed.
dpkg: error processing blah (--install):
 dependency problems - leaving unconfigured
Processing triggers for shared-mime-info ...
Processing triggers for desktop-file-utils ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for gnome-menus ...
 blah
Unfortunately the system I am installing doesn't have (and will not have) internet access. How can I provide the packages required, in the same deb installer ?
Or, how can I disable checking for dependencies, since I am providing the required libs ?
(Ubuntu 12.04 if that is relevant)
Update: I ran
sudo dpkg -i --ignore-depends=libqt4-help,libqtwebkit4 /path/blah_1.0-1_i386.deb
The program installed correctly and ran perfectly.
Inside the package, in the /DEBIAN/control, i see listed the unwanted dependencies.
After calling dh_make I had no dependencies in the control file.
The dpkg-buildpackage must have placed the dependencies after checking (likely for assistant).
Can I remove them somehow ? Can I put a flag somewhere not to include dependencies ?
Or... still.... can I add in my packaging thing the deb packages and is there a command I can give to pre-install as part of the package installation ?
If there is no solution.... I suppose I can provide a script to run the dpkg command as above, with ignore-depends, but then he package cannot be installed from the Software Center...
Thalia
  • 351
According to man dpkg-source:
-Dfield=value
      Override or add an output control file field.
And from man dpkg-buildpackage:
--source-option=opt
      Pass option opt to dpkg-source.
So perhaps you could override the Depends field thus:
dpkg-buildpackage --source-option='-DDepends=...' ...
astrob0t
  • 1,766
muru
  • 207,228
