how to check bad sector on HDD 6TB
koko@Rumah:~$ sudo badblocks -v /dev/sda2
[sudo] password for koko:
badblocks: Value too large for defined data type invalid end block (5751976960): must be 32-bit value
I wanted to run badblocks with the actual blocksize of the disk which I found by running sudo -n blockdev --getbsz /dev/disk
My solution was to create a bunch of partitions of size 2TB and badblocks them individually, avoiding the int32 overflow.
