I'm not new to Linux, but I newly installed it on this PC. Its been as smooth as always, but I have a problem with the display. It runs in 1024x768 on a 1920x1080 monitor, which is not exactly fun. In the "Display" dropdown, it says "1024x768" and "800x600". Also, its recognizing my VGA screen as "Built-In" which is not correct.
I have done searching and have not found an answer. However, most of these answers tell me to change my "xorg.conf". I don't have that file. And I also got an error called Cant get gamma for native screen or something like that when trying to add something with xrandr.
How can I make the resolution correct?
fosslinux
  • 3,881
Firstly you could try the proprietary nvidia drivers and see if the system corrects itself. I highly recommend to try this first, except of course if you got beef with non open source software running on your install.
Anyway, if you still want the nouvau drivers (hoping i spelled that right :P) or the nvidia drivers fail to fix your problem you can forcibly add your resolution (never ever mess around with the Xorg.conf files - seriously it can hang your system) with xrandr
cvt 1920 1080
this will tell you what option/arguments you should use for the next command ie:cvt 1024 600 output:# 1024x600 59.85 Hz (CVT) hsync: 37.35 kHz; pclk: 49.00 MHz Modeline "1024x600_60.00" 49.00 1024 1072 1168 1312 600 603 613 624 -hsync +vsync so for the next command you should copy everything for the 'Modeline' and after:
xrandr --newmode "1024x600_60.00" 49.00 1024 1072 1168 1312 600 603 613 624 -hsync +vsync
then you must add the new resolution to your output (run xrandr to find your output name ie:VGA1)
xrandr --addmode VGA1 1024x600_60.00
finally to change to your newly added resolution run: xrandr --output VGA1 --mode 1024x600_60.00
PS: some or all the commands listed may require admin rights (super-cow) so before all that just run sudo su to log as root
source (and more detail):https://wiki.archlinux.org/index.php/xrandr#Adding_undetected_resolutions
-1
I recently had this issue. What solved it was to simply update my Ubuntu.
  1. Run 'Software Updater'
  2. Restart Computer when prompted
