I am pretty new to Ubuntu (in case that fact is not immediately obvious).
I setup a machine with Ubuntu 14.04 for some people in our church. In setup, I used their user name to configure the computer. Afterwards, I added my name and set it as an administrator (in the GUI). As administrator, I want to be able to see all files that they add or edit. I tried adding root permissions to my account with 'visudo' but that did not give me the access I wanted.
I cannot determine how to grant access to my account for their files. In addition, I do not even have access to the primary partition on the hard drive, or to USB drives that are inserted into the computer. Please explain how I can gain access to view and modify their files, and how I can access the primary drive and USB drives that may be added.
The drive partition and USB drives are listed under media/firstuser. The firstuser folder is owned by root. I added my user name to root group, but still cannot access the firstuser folder.
And since appreciation is not to be added later, thank you in advance. :-)
RaifMT
  • 139
Probably the most novice friendly solution for browsing files is to start nautilus with root privileges.
gksu nautilus
If you want to change permissions for files you should have a look at chmod. See also here http://www.perlfect.com/articles/chmod.shtml
It might be that you encrypted the home partition of the other user. If that is the case and you don't have the password for the other user, you are however out of luck.
cstich
  • 86
I have had same problem like you, and you proabaly need to use thunar, and to do this you have to enter in the terminal this:
  sudo -i
  gksudo thunar
and then you can alter promising to all of you files, and it might work fine this way.
Michael
  • 2,597
