I'm trying to install the gnome desktop environment on my Ubuntu 14.04LTS using the command line:
$sudo apt-get install gnome-shell
but the terminal keeps saying:
"Some packages could not be installed. This may mean that you have
 gnome-shell : Depends: gnome-settings-daemon (>= 3.4.0) but it is not going to be installed
               Recommends: gnome-control-center but it is not going to be installed
E: Unable to correct problems, you have held broken packages."
how do i fix this?
muru
  • 207,228
You can try this method of installation and you may not face any issue:
sudo add-apt-repository ppa:gnome3-team/gnome3-staging
sudo apt-get update
sudo apt-get dist-upgrade
To install all the GNOME 3 apps:
sudo apt-get install bijiben polari gnome-clocks gnome-weather gnome-maps gnome-music gnome-photos gnome-documents gnome-contacts epiphany-browser gnome-sushi gnome-boxes gnome-shell-extensions gnome-tweak-tool
copy paste these commands in terminal one-by-one.
NOTE:"The packages here have been deemed not ready for general use, they have known bugs and/or regressions, sometimes of a critical nature. Mostly things should run smoothly but be prepared to use ppa-purge, when you encounter issues"
Alex Jones
  • 8,192
