I have a high resolution screen on my laptop (3200x1800px) and I disabled the boot-image
( How do I disable the boot splash screen, and only show kernel and boot text instead? )
I also managed to enlarge the font in grub by uncommenting the line
GRUB_GFXMODE=640x480
in /etc/default/grub
But the boot messages during startup are still really tiny and hardly readeable. The same as if I change to a console screen by pressing Ctrl+Alt+F1.
How can I enlarge the font on the console too?
rubo77
  • 34,024
  • 52
  • 172
  • 299
You can configure the font on tty console with
sudo dpkg-reconfigure console-setup
leave all settings as they are but the last one, where you can chose the size.
(You have to reboot to get the new font on your console.)
Update:
This doesn't seem to work anymore on 15.04, but you can install the custom Ubuntu fonts for your console:
sudo apt-get install fonts-ubuntu-font-family-console
And create a script /usr/local/bin/fontset with this command:
#!/bin/sh
setfont /usr/share/consolefonts/Uni3-TerminusBold32x16.psf.gz
(choose the desired font out of the folder /usr/share/consolefonts/)
You can either call fontset each time on your console after using Ctrl+Alt+F1
or add these lines to your ~/.profile:
#load larger font on tty
if [ "$TERM" == "linux" ]; then
 #sleep 1 # add this if you have problems
fi
This starts your script only if you are on a tty console.
rubo77
  • 34,024
  • 52
  • 172
  • 299
#1 - install the right font and size to the grub. (30 denotes the font size, which works for me. If you want it bigger, just increase it.).
sudo grub-mkfont -s 30 -o /boot/grub/DejaVuSansMono.pf2 /usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
#2. Edit /etc/default/grub - use sudo nano /etc/default/grub and add GRUB_FONT=/boot/grub/DejaVuSansMono.pf2 while you're at it (and for good measure) also add your appropriate screen resolution on that same file too GRUB_GFXMODE="your screen resolutionx32" which will look something like GRUB_GFXMODE=3840x2160x32 . On the line below it add GRUB_GFXPAYLOAD_LINUX="keep". The "keep" command is important bc your grub can throw errors without it.
#3. Update your grub sudo update-grub Now reboot, sit back, and revel in the beauty of being able to actually read your grub screen!
