I like this command to convert pdf pages to png images:
pdftoppm -png *.pdf prefix
(my source is this answer)
I would like to add a command to Thunar custom actions that would convert the selected pdf's pages to separate images.
When I use the option "Open terminal here" in the folder containing the pdf, and then add the above command, it works fine.
So, what I would like is a Thunar custom action with a command that (1): opens a terminal window in that folder, AND (2): runs that command in the terminal window
If I create a custom action with the command xfce4-terminal, Appearance conditions: Directories, that will open the terminal in that folder.
If I replace the command with xfce4-terminal -e "pdftoppm -png *.pdf prefix", nothing seems to happen. To see clearer it is useful to keep that terminal window open after the command was run, but I do not know how to do that with the Xfce terminal.
Using gnome-terminal I create a profile called new1 with the setting "When command exits: Hold the terminal open" then add to custom action this command:
gnome-terminal --window-with-profile=new1 -e "pdftoppm -png *.pdf prefix"
But this gives an error;
I/O Error: Couldn't open file '*.pdf': No such file or directory.
