i am trying to install mysqlworkbench in my ubuntu using
sudo dpkg -i mysql-workbench-community-6.0.9-1ubu1310-amd64.deb.3
but getting following errors
(Reading database ... 188276 files and directories currently installed.)
Preparing to replace mysql-workbench-community 6.0.9-1ubu1310(using mysql-                workbench-   community-6.0.9-1ubu1310-amd64.deb.3) ...
Unpacking replacement mysql-workbench-community ...
dpkg: dependency problems prevent configuration of mysql-workbench-community:
mysql-workbench-community depends on libctemplate2; however:
Package libctemplate2 is not installed.
mysql-workbench-community depends on libglib2.0-0 (>= 2.35.9); however:
Version of libglib2.0-0 on system is 2.32.4-0ubuntu1.
mysql-workbench-community depends on libglibmm-2.4-1c2a (>= 2.36.2); however:
Version of libglibmm-2.4-1c2a on system is 2.32.0-0ubuntu1.
mysql-workbench-community depends on libgtkmm-2.4-1c2a (>= 1:2.24.0); however:
Package libgtkmm-2.4-1c2a is not installed.
mysql-workbench-community depends on libpango-1.0-0 (>= 1.18.0); however:
Package libpango-1.0-0 is not installed.
mysql-workbench-community depends on libpangocairo-1.0-0 (>= 1.14.0); however:
Package libpangocairo-1.0-0 is not installed.
mysql-workbench-community depends on libpcrecpp0 (>= 7.7); however:
Package libpcrecpp0 is not installed.
mysql-workbench-community depends on libtinyxml2.6.2; however:
Package libtinyxml2.6.2 is not installed.
mysql-workbench-community depends on libzip2 (>= 0.10); however:
Package libzip2 is not installed.
mysql-workbench-community depends on python-paramiko; however:
Package python-paramiko is not installed.
mysql-workbench-community depends on python-pysqlite2; however:
Package python-pysqlite2 is not installed.
dpkg: error processing mysql-workbench-community (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils ...
Processing triggers for bamfdaemon ...
Rebuilding /usr/share/applications/bamf.index...
Processing triggers for gnome-menus ...
Processing triggers for shared-mime-info ...
Processing triggers for hicolor-icon-theme ...
user7
  • 103
I think you're going at it the wrong way. You are having dependency issues trying to install MySQL Workbench 6.0.9, when you could easily install MySQL Workbench 6.0.8 in Ubuntu 14.04 from the Ubuntu Software Center or from the terminal using the command:
sudo apt-get install mysql-workbench
karel
  • 122,292
  • 133
  • 301
  • 332
