This questions was already asked here 7 months, but had no correct answer. So I would like to ask again: Is there an alternative to AutoKey, which executes text expansions, when specific abbreviations are typed? My problem is that AutoKey skips randomly letters when I use this function in Thunderbird, while it always works fine in a text editor. This problem occurs since Ubuntu 13.10.
Snippy seems to work for me quite nicely. No GUI, but quite functional. Glad I finally found a replacement.
The link also mentions another choice in the comments.
Snippy itself is available via a tinyurl and installation is as follows:
curl -L "http://tinyurl.com/o9d6ch5" > snippy.sh
chmod 755 snippy.sh
./snippy.sh
Alternatively, there appears to be an enhanced version located here in github
Installation works the same.
- 254
Snippy actually proved to be a very good idea, now I have a menu of scripts on the desktop.
A restructuring proved necessary, though, as xdotool doesn't work so well these days with window names ( and I tried every possible solution -my OS is Ubuntu 22.04 w/XFCE ).
I kept only dmenu:
#!/bin/bash
# snippy re-engineered
DIR=${HOME}/.snippy
APPS="dmenu"
DMENU_ARGS="-b"
TERMINAL=tilix # change to your favorite
init(){
for APP in $APPS; do
which $APP >/dev/null 2>&1 || {
read -p "install the following required utils? : $APPS (y/n)" reply
if [ "$reply" == "y" ]; then
sudo apt install --assume-yes ${APPS};
fi
done
if [ ! -d "$DIR" ]; then
echo -e "created $DIR\n";
mkdir "$DIR";
printf 'hi it is $(date)' > "$DIR""/test";
fi
return 0
run(){
Use the filenames in the snippy directory as menu entries.
cd ${DIR}
Get the menu selection from the user.
FILE=find -L . -type f | grep -v '^\.$' | sed 's!\.\/!!' | sort | /usr/bin/dmenu ${DMENU_ARGS}
open terminal and execute
if [ -z "$FILE" ]; then
exit
else
${TERMINAL} --title=$FILE --command="$SHELL $DIR/$FILE"
fi
init && run
This update comes after many years, but it's proved helpful.
- 768
- 1
- 5
- 13
