48
How do you nicely stop all postgres processes with pg_ctl (or otherwise), when you don't recall what the database directory is, nor have the PGDATA environment variable defined?
matanox
  • 1,861
It's safe to:
sudo pkill -u postgres
That kills all processes running as user postgres. Or:
pkill postgres
That kills all processes named 'postgres'.
Do not use kill -9 (kill -KILL). Just kill (without options) does a SIGTERM, which is what you want.
Alternatively, you can check the pgdata location if you can connect to PostgreSQL. For example:
sudo -u postgres psql -c "SHOW data_directory";
...or by checking its environment variables in /proc/[postmaster pid]/environ, where you identify the postmaster with ps -fHC postgres. Look for the one that's the parent of the other postgres processes. For example:
postgres   794     1  0 Nov06 ?        00:00:03 /usr/pgsql-9.3/bin/postgres -D /var/lib/pgsql/9.3/data -p 5432
postgres   857   794  0 Nov06 ?        00:00:00   postgres: logger process
postgres   871   794  0 Nov06 ?        00:00:00   postgres: checkpointer process
postgres   872   794  0 Nov06 ?        00:00:00   postgres: writer process
postgres   873   794  0 Nov06 ?        00:00:00   postgres: wal writer process
postgres   874   794  0 Nov06 ?        00:00:03   postgres: autovacuum launcher process
postgres   875   794  0 Nov06 ?        00:00:07   postgres: stats collector process
Its datadir will generally be shown on its command line.
Eliah Kagan
  • 119,640
Craig Ringer
  • 5,494
  • 24
  • 18
It makes me nervous seeing kill and postgres in the same command. To answer the question using only pg_ctl, that would be:
pg_ctl -D $(psql -Xtc 'show data_directory') stop
The -X argument says to ignore the .psqlrc file. This is useful if you have psql configured to emit the time taken by a query (via the \timing command).
The -t argument says to remove the column name at the top of the output and the total number of rows produced.
The -c argument contains the SQL code to be executed.
Running a bare psql -c 'show data_directory' will probably produce the following output:
      data_directory
 /path/to/postgresql/data
(1 row)
Hence, backticking this through $( ... ) will deliver /path/to/postgresql/data to the -D argument of pg_ctl, which will then stop the database in an orderly manner.
dland
  • 180
This work for me ref. https://stackoverflow.com/a/5408501/248616
SELECT pg_terminate_backend(pid) FROM pg_stat_activity WHERE datname = 'YOUR_NAME';
Nam G VU
  • 2,378
You can simply run the command
systemctl stop postgresql
When you wish to restart it run
systemctl start postgresql
  • It is likely these commands will require you to append sudo
Gino
  • 123
