Recently I did a "clean" install of Ubuntu 14.10 and I had everything running fine, using my AMD Radeon HD 6630M as the default graphics card, without issue (I have one of those stupid dual-graphics cards setups).
But when I was having problems with the HDMI output (the screen flickering and the entire desktop off-center), I thought it might be a driver issue, so I changed my video card to the Intel card using Catalyst... Then everything went pear-shaped.
Now, I cannot access System Settings at all - it just changes the mouse/touchpad cursor to the "loading" variant, then nothing.
Further to this, when my laptop automatically suspends after the user-specified time (which I cannot see, because I cannot access the System Settings), I cannot come out of standby mode... Pressing keys on my laptop (well, the external keyboard - my laptop's keyboard no longer works) does nothing but causes my laptop to continue to display a black screen! I tried to change back to my Radeon HD 6630M using Catalyst, but after entering the correct password in the pop-up dialog box, I get nothing!
Then I tried to re-install it as per my original support request: Need help getting switchable graphics working under Ubuntu 14.10
But all I get is errors:
~$ sudo apt-get install fglrx fglrx-core fglrx-amdcccle fglrx-pxpress
[sudo] password for gregoryopera:
Reading package lists... Done
Building dependency tree
fglrx-pxpress is already the newest version.
fglrx is already the newest version.
fglrx-amdcccle is already the newest version.
fglrx-core is already the newest version.
0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
gregoryopera@gregoryopera-VPCCB15FG:~$ sudo ln -svT /usr/lib /usr/lib64 #Only for Ubuntu 64bits
ln: failed to create symbolic link ‘/usr/lib64’: File exists
gregoryopera@gregoryopera-VPCCB15FG:~$ sudo amdconfig --initial
amdconfig: No supported adapters detected*
Any help would be appreciated.
Okay, everything's fixed.
What I had to do was purge (i.e. completely remove) all of my AMD Radeon HD 6630M drivers and software:
sudo apt-get purge "fglrx.*"
Restart.
Install all of my AMD Radeon HD 6630M drivers and software from scratch again:
Restart.
Everything works fine now!
Note to self, avoid the HDMI port and the embedded (Intel) graphics...
Thanks go to @BrunoPereira and @Snorky35 for their respective instructions posted here and here
