Once I Press install I get:
Package dependencies cannot be resolved
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
Details
liferea: Depends: libatk1.0-0 (>= 1.12.4) but 2.0.0-0ubuntu1 is to be installed
         Depends: libc6 (>= 2.7) but 2.13-0ubuntu13 is to be installed
         Depends: libfontconfig1 (>= 2.8.0) but 2.8.0-2.1ubuntu3 is to be installed
         Depends: libfreetype6 (>= 2.2.1) but 2.4.4-1ubuntu2.1 is to be installed
         Depends: libgconf2-4 (>= 2.31.1) but 2.32.2-0ubuntu2 is to be installed
         Depends: libgdk-pixbuf2.0-0 (>= 2.22.0) but 2.23.3-0ubuntu1 is to be installed
         Depends: libglade2-0 (>= 1:2.6.1) but 1:2.6.4-1build1 is to be installed
         Depends: libglib2.0-0 (>= 2.24.0) but 2.28.6-0ubuntu1 is to be installed
         Depends: libgtk2.0-0 (>= 2.18.0) but 2.24.4-0ubuntu2 is to be installed
         Depends: libice6 (>= 1:1.0.0) but 2:1.0.7-1ubuntu1 is to be installed
         Depends: libnotify1-gtk2.10 but it is a virtual package
         Depends: libpango1.0-0 (>= 1.14.0) but 1.28.4-0ubuntu1 is to be installed
         Depends: libsoup2.4-1 (>= 2.26.1) but 2.34.0-0ubuntu1 is to be installed
         Depends: libsqlite3-0 (>= 3.7.3) but 3.7.4-2ubuntu5 is to be installed
         Depends: libunity4 (>= 3.4.6) but 3.8.4-0ubuntu1 is to be installed
         Depends: libxml2 (>= 2.7.4) but 2.7.8.dfsg-2ubuntu0.1 is to be installed
         Depends: gconf2 (>= 2.28.1-2) but 2.32.2-0ubuntu2 is to be installed
         Depends: liferea-data (= 1.6.4-1ubuntu7) but 1.6.5-1~mmwkt1 is to be installed
Manish Sinha
  • 11,671
From what I can see this was a temporary glitch in the package system - so it should be fine now.
Update your computer (as is outlined in this question: How do I update Ubuntu?) and try again.
jrg
  • 61,707
If you get this kind of problems, the first thing to do is to run these two commands
sudo apt-get update
followed by
sudo apt-get upgrade
I sometimes also run
sudo apt-get dist-upgrade
Then try installing
Manish Sinha
  • 11,671
