Please let me know what to be done here. I am trying to install Hadoop in Ubuntu.The ssh connectivity is throwing error
$ sudo apt-get install openssh-server
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
openssh-server :
Depends: openssh-client (= 1:6.6p1-2ubuntu1) but 1:6.6p1-2ubuntu2 is to be installed
Recommends: ncurses-term but it is not going to be installed
Recommends: ssh-import-id but it is not going to be installed
$ ifconfig
eth0 Link encap:Ethernet HWaddr 08:00:27:3a:a6:f3
inet addr:192.168.0.112 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::a00:27ff:fe3a:a6f3/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:15543 errors:0 dropped:0 overruns:0 frame:0
TX packets:10845 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:11839138 (11.8 MB) TX bytes:1448354 (1.4 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2175 errors:0 dropped:0 overruns:0 frame:0
TX packets:2175 errors:0 dropped:0 overruns:0
carrier:0 collisions:0 txqueuelen:0
RX bytes:217643 (217.6 KB) TX bytes:217643 (217.6 KB)
openssh-server :
$ sudo iptables -L
Chain INPUT (policy ACCEPT) target prot opt source destination Chain FORWARD (policy ACCEPT) target prot opt source destination Chain OUTPUT (policy ACCEPT) target prot opt source destination
$ sudo iptables -A INPUT -p tcp --dport ssh -j ACCEPT
$ ssh localhost ssh: connect to host localhost port 22: Connection refused
