My touchpad stops working after closing and reopening my laptop. This problem exists since upgrading to 14.10 from 14.04. I have to reboot Ubuntu to get it working again. I already tried rmmod psmouse, but it only gives me this error:
rmmod: ERROR: Module psmouse is not currently loaded
my xinput list is as follows: http://pastebin.com/wL8XhNve
Can someone help me identify this problem?
I've just tried the script mentioned here https://bugs.launchpad.net/ubuntu/+s...079/comments/7 (copied below) with a positive result.
This is what I did to fix this for me:
# sudo touch /etc/pm/sleep.d/10_touchpad
# sudo chmod 755 /etc/pm/sleep.d/10_touchpad
Then edit the file 10_touchpad and paste the following into it:
#!/bin/sh
case "${1}" in
     resume|thaw)
             rmmod hid_multitouch
             modprobe hid_multitouch
esac
Mitty
  • 746
It seems the touchpad entry is showing "ELAN0501:00 04F3:300B UNKNOWN". Is it taken when the touchpad is working or when it is down? Can you live boot from 14.04 and check the output?
Also share your laptop model info which might help others support you better.
A few pointers in case the output is the same: I had a problem with Sony VAIO earlier where I had to use scripts to toggle the touchpad as it wouldn't work. More of a keybind issue but this is what I did: http://tuxdiary.com/2014/03/07/toggle-sony-vaio-touchpad-on-ubuntu-14-04/
And here's how to run scripts on suspend/resume: http://tuxdiary.com/2013/07/23/suspend-on-lid-close-on-lxde-ubuntu/
Arun
  • 151
The suggested /etc/pm/sleep.d/ hooks may not make an effect if systemd-sleep is doing the suspend instead of pm-suspend commannd; this may be the case if, for example, you are using Xfce's exit/suspend menu instead of pm-suspend from the commannd line.
I needed some time to understand this; thanks to https://askubuntu.com/a/643793/19753.
So I have put (additionally to /etc/pm/sleep.d/75touchpad which contains in my case the common modprobe psmouse-workaround mentioned by OP) the file /lib/systemd/system-sleep/my-touchpad (executable):
#!/bin/sh
case "$1/$2" in
  post/suspend)
      exec /etc/pm/sleep.d/75touchpad resume
  post/hybrid-sleep)
      /etc/pm/sleep.d/75touchpad thaw
  post/*) # hibernate
      exec /etc/pm/sleep.d/75touchpad thaw
  pre/suspend)
      exec /etc/pm/sleep.d/75touchpad suspend
  pre/hybrid-sleep)
      exec /etc/pm/sleep.d/75touchpad hibernate
  pre/*) # hibernate
esac
It's a kind of a universal proxy to call a script originally put for pm-utils.
