For security reasons, I'd like to disable the SMB1 protocol in samba. Is it possible? I'm running Ubuntu 14.04 LTS.
Asked
Active
Viewed 8.0k times
My testing with Nessus has indicated SMBv1 is only disabled when setting
min protocol = SMB2
in the [global] section of smb.conf . Core, LANMAN2 and NT1 were all still flagged as being vulnerable.
Christian M.
- 106
While I'm not sure where SMB1 fits in (My guess is CORE), here is the order of protocols from "man smb.conf"
max protocol (G)
The value of the parameter (a string) is the highest protocol level that will be supported by the server.
Possible values are :
· CORE: Earliest version. No concept of user names.
· COREPLUS: Slight improvements on CORE for efficiency.
· LANMAN1: First
modern version of the protocol. Long filename support.
· LANMAN2: Updates to Lanman1 protocol.
· NT1: Current up to date version of the protocol. Used by Windows NT. Known as CIFS.
· SMB2: Re-implementation of the SMB protocol. Used by Windows Vista and newer.
min protocol (G)
The value of the parameter (a string) is the lowest SMB protocol dialect than Samba will support. Please refer to the max
protocol parameter for a list of valid protocol names and a brief description of each. You may also wish to refer to the C
source code in source/smbd/negprot.c for a listing of known protocol dialects supported by clients.
If you are viewing this parameter as a security measure, you should also refer to the lanman auth parameter. Otherwise, you
should never need to change this parameter.
Default: min protocol = CORE
Example: min protocol = NT1
Clark Mercer
- 21
I think that I managed to disable SMB1 protocol with these two lines in the [global] section:
min protocol = LANMAN2
max protocol = SMB3
I'm still not completely sure about the order of protocols in Samba, but I'm quite confident that LANMAN2 is after SMB1.
Avio
- 3,098
I think what you are looking for in the smb.conf file is:
### server min protocol = SMB2_10 client min protocol = SMB2 client max protocol = SMB3
