Hi guys im not been able to find a solution to this issue and wonder if you can help me. Im looking for a tool that will sit in the background and watch a twitch stream URL and when the live broadcast starts it will download to my local machine. your help would be greatly appreciated.
As far as the downloading part of your question is concerned you can use livestreamer, e.g.:
livestreamer <livestream-url> best -o vod.mp4
For installation instructions check out this answer by @henry.
It actually shouldn't be too difficult to monitor stream activity via the Twitch API. For instance, you could perform a simple curl request piped to grep to identify if the stream is offline or if there's another type of error:
curl -s  https://api.twitch.tv/kraken/streams/totalbiscuit | grep '"stream":null'
This will return as true if no stream is running at the moment.
With that in mind you could design a simple loop that would check for active streams every few minutes, e.g.:
#!/bin/bash
Channel="totalbiscuit"
while sleep 60; do
  if ! curl -s "https://api.twitch.tv/kraken/streams/$Channel" | grep -q '"stream":null'; then
    echo "$Channel is live. Downloading stream..."
    livestreamer "http://www.twitch.tv/$Channel" best -o "${Channel}_livestream.mp4"
  else
    echo "$Channel is offline"
  fi
done
Or, slightly more complex and with more sanity checks:
#!/bin/bash
# Simple Twitch Poller
# Author: Glutanimate
# License: GPL v3
# Dependencies: livestreamer
# Description: Polls twitch channel status and downloads stream if user is online
Usage="$0 <space-separated list of twitch channels>"
Channels=($@)
Interval="60" # polling interval in seconds
if [[ -z "$Channels" ]]; then
  echo "Error: No channels provided"
  echo "Usage: $Usage"
  exit 1
fi
while true; do
  for i in ${Channels[@]}; do
    StreamData="$(curl -s  "https://api.twitch.tv/kraken/streams/$i")"
    if echo "$StreamData" | grep -q '"status":404'; then # 404 Error
      echo "Error: $i does not exist."
      break 2
    elif echo "$StreamData" | grep -q '"stream":null'; then # Channel offline
      echo "$i is offline."
    else # Channel online
      echo "$i is live. Downloading stream..."
      livestreamer "http://www.twitch.tv/$i" best -o "$(date +"${i}_TwitchVOD_%Y-%m-%d_%H%M%S.mp4")"
    fi
  done
  sleep "$Interval"
done
To try this script out, copy and paste the codeblock above into a new empty text file, save it as twitch_poller.sh or something similar and make it executable via the Properties menu of your file manager (Right click → Properties → Permissions → Allow executing file as program).
Make sure you have livestreamer installed, then run the script from a terminal while providing the twitch channels you want to monitor, e.g.:
$ './twitch_poller.sh' totalbiscuit TSM_Dyrus
totalbiscuit is offline.
TSM_Dyrus is live. Downloading stream...
[cli][info] Found matching plugin twitch for URL http://www.twitch.tv/TSM_Dyrus
[cli][info] Available streams: audio, high, low, medium, mobile (worst), source (best)
[cli][info] Opening stream: source (hls)
[download][..D_2014-11-07_001503.mp4] Written 3.1 MB (6s @ 460.6 KB/s)
You can adjust the polling interval by setting the Interval variable in the script.
Glutanimate
  • 21,763
