My question is what generic file should I delete that won't affect the Ubuntu system. Files inside /boot directory are all ends up with generic. So what are the right files should I delete so that I can install the new updates?
Asked
Active
Viewed 528 times
run sudo dpkg --list 'linux-image*' | grep ^ii to see all the kernels you have installed.
run uname -r to see your currently running kernel. Do not remove this kernel (linux-image)
use apt-get purge to remove the other images you don't need anymore, e.g., if you are using 3.13.0-34, remove the others:
sudo apt-get purge linux-image-3.13.0-32-generic linux-image-3.13.0-33-generic
riotejas
- 1,006
- 8
- 10
Had the same trouble a while ago and apt-get purge didn't work. Although sudo nautilus and than „manually” removing „older kernels” (shift-delete) helped.
user265721
- 71
