Need a step by step procedure for creating a kickstart server on Ubuntu 14.04 LTS
This is a good step-by-step guide
TL;DR; use isohybrid after repacking the custom iso
To make this usb, I used a virtual machine with Ubuntu 14.04 installed. The goal here is to make a bootable usb that doesn’t require selection of things like keyboard layout, language, etc. We want an automatic install of an Ubuntu server.
We need to get the ubuntu image that we’re going to be customizing for our installation.
wget http://releases.ubuntu.com/14.04/ubuntu-14.04.2-server-amd64.isoWe’re going to need a place to mount the unpacked iso file.
sudo mkdir -p /mnt/isoAfter we have created a mount point for it, now we have to mount it. This will expose the files that are held inside the iso. Unfortunately, the files will be read-only
. sudo mount -o loop ubuntu-14.04.2-server-amd64.iso /mnt/iso
In order to modify the files, we need to copy them to a directory where we can modify them, so we’ll create the directory and then copy the files to it.
sudo mkdir -p /opt/ubuntuiso sudo cp -rT /mnt/iso /opt/ubuntuisoOur new working directory will be /opt/ubuntuiso
cd /opt/ubuntuisoIn order to avoid being prompted for language selection in the installation process, we need to tell it what language we’re going to use. In this case, en is being used because I speak english.
echo en | sudo tee isolinux/langNow we are actually going to build the kickstart file with a program called system-config-kickstart. So we make sure it’s installed and then run it.
sudo apt-get install system-config-kickstart system-config-kickstartThen save the file from the GUI in
/opt/ubuntuiso/. This should save a file called ks.cfg. My ks.cfg looks like the following#Generated by Kickstart Configurator #platform=AMD64 or Intel EM64T #System language lang en_US #Language modules to install langsupport en_US #System keyboard keyboard us #System mouse mouse #System timezone timezone America/Denver #Root password rootpw --disabled #Initial user user ubuntu --fullname "ubuntu" --iscrypted --password $1$MQ0zGB4W$pwjX8nolgr2RJch2Omamt. #Reboot after installation reboot #Use text mode install text #Install OS instead of upgrade install #Use CDROM installation media cdrom #System bootloader configuration bootloader --location=mbr #Clear the Master Boot Record zerombr yes #Partition clearing information clearpart --all --initlabel #Disk partitioning information part /boot --fstype ext2 --size 100 --asprimary part swap --recommended part / --fstype ext4 --size 1 --grow #System authorization infomation auth --useshadow --enablemd5 #Network information network --bootproto=dhcp --device=eth0 #Firewall configuration firewall --disabled #Do not configure the X Window System skipx %post #!/bin/bash exec < /dev/tty6 > /dev/tty6 chvt 6 echo 'Acquire::http { Proxy "http://10.2.4.27"; };' > /etc/apt/apt.conf.d/02proxy apt-get update apt-get -y upgrade apt-get -y dist-upgrade apt-get install -y git ansible openssh-server vim chvt 1There is a little bit of hijacking done in the postscript (everything after
%post). The line beginning with exec and the following line (chvt 6) are forcing the installer show the output from the commands that are run after that. The reason for this is that the loading bar will not move during the installation, and it can appear as though the installer has hung. The following line that does the proxy is for the apt-cache on our local network. The final line (chvt 1) reverts the output to the main installer.Now we need to add the preseed file so that we can avoid other questions.
echo 'd-i partman/confirm_write_new_label boolean true d-i partman/choose_partition \ select Finish partitioning and write changes to disk d-i partman/confirm boolean true' | sudo tee ks.preseedNow we need to tell the installer about the files that we just saved, so we need to modify isolinux/txt.cfg. First we need to make the file writable.
sudo chmod +w isolinux/txt.cfgThen we need to replace the append line of the following section
label install menu label ^Install Ubuntu Server kernel /install/vmlinuz append file=/cdrom/preseed/ubuntu-server.seed vga=788 initrd=/install/initrd.gz quiet --Replace the append line with
append file=/cdrom/preseed/ubuntu-server.seed initrd=/install/initrd.gz ks=cdrom:/ks.cfg preseed/file=/cdrom/ks.preseed --Save and exit the file. We also need to make sure that we put the file back in its original state, so remove the write permissions.
sudo chmod -w isolinux/txt.cfgNow create the new iso file that we will use to create the bootable usb.
sudo mkisofs -D -r -V "ATTENDLESS_UBUNTU" -cache-inodes -J -l -b isolinux/isolinux.bin -c isolinux/boot.cat -no-emul-boot -boot-load-size 4 -boot-info-table -o /opt/autoinstall.iso /opt/ubuntuisoIn order to finalize the bootable iso for a usb, we need to hybridize it.
sudo isohybrid /opt/autoinstall.isoAfter hybridizing it, we can push it to the usb drive. The usb drive in my virtual machine shows up in
/dev/sdb, but you need to use the correct label, so replace X accordingly Make sure that the usb drive is unmounted.sudo umount /dev/sdXAnd finally push the iso onto the usb drive. (Please note **this destroys data on the target device - make sure you know what you are doing)
sudo dd if=/opt/autoinstall.iso of=/dev/sdXNow your usb drive should be ready for installation!
- 72,312
The complete solution:
Remaster a CD, ie, download a non-graphical Ubuntu installation ISO (server or alternate installation CD) and mount it. In this case, your Ubuntu 14 ISO.
sudo mount -o loop ubuntu.iso /mnt/iso
Copy the relevant files to a different directory
Prevent the language selection menu from appearing
cd /opt/ubuntuiso
Use GUI program to add a kickstart file named ks.cfg
system-config-kickstart # save file to ks.cfg
To add packages for the installation, add a %package section to the ks.cfg kickstart file, append to the end of ks.cfg file something like this.
%packages
@ ubuntu-server
openssh-server
ftp
build-essential
This will install the ubuntu-server "bundle", and will add the openssh-server, ftp and build-essential packages.
Add a preseed file, to suppress other questions
Set the boot command line to use the kickstart and preseed files
sudo nano isolinux/txt.cfg
Search for
label install
add ks=cdrom:/ks.cfg and preseed/file=/cdrom/ks.preseed to the append line. You can remove the quiet and vga=788 words. It should look like
Now create a new iso
That's it. You'll have a CD that would install an Ubuntu system once you boot from it, without requiring any input.
Tweak the ks.cfg and preseed files as needed.
- 72,312
- 46
