I'm using MythTV and MythWeb has suddenly stopped working. When I try to connect, my web browser reports:
Unable to connect Firefox can't establish a connection to the server at 192.168.1.100.
I still have no trouble connecting to the internet, and ifconfig results seem OK:
eth1 Link encap:Ethernet HWaddr 00:1c:c0:79:83:13
inet addr:192.168.1.100 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::21c:c0ff:fe79:8313/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:963141 errors:0 dropped:90 overruns:0 frame:0
TX packets:726145 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:449248447 (449.2 MB) TX bytes:174625833 (174.6 MB)
Interrupt:20 Memory:e3400000-e3420000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:6009249 errors:0 dropped:0 overruns:0 frame:0
TX packets:6009249 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2149138281 (2.1 GB) TX bytes:2149138281 (2.1 GB)
I get the same error when I tryhttp://192.168.1.100/ so I think this is probably less a mythweb error and more an...Apache error?
Update: Since it appears it may be port 80 related (thanks Nathan), I checked my /etc/apache2/ports.conf file, which did contain a "Listen 80" line, so I checked and apache's not running (facepalm)!
Trying to start apache with: sudo /etc/init.d/apache2 start returns:
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using ::1. Set the 'ServerName' directive globally to suppress this message
(2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for main error log
(2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for error log of vhost defined at /etc/apache2/sites-enabled/000-default.conf:1
