when I try to run HTC Evo 4.3 (or other devices, it doesn't matter) in Genymotion (2.3.0 x64) (with VirtualBox 4.3.10) on Ubuntu 14.04, I get:
Error 31 : The virtual device got no IP address.
The virtual device got no IP address. The VirtualBox DHCP server has not assigned an IP address to the virtual device.
My settings in Virtual Box are the following:
Settings Virtual Box Settings Virtual Box
How can I assign an IP address to the device?
Any help will be appreciated. Thanks!
subodh007
  • 350
The responsible thing that is assigning dynamic IPs for you is called DHCP server so you have to enable it to resolve this issue.
Try the following:
Open VirtualBox's Preferences and under Network section, check the adapter named "vboxnet0" in "Host-Only Networks", double click on it and make sure to apply the following configuration there.
6- Double click on that name and apple the following configuration
Adapter Tab:
  • IPv4 Adapter: 192.168.65.1
  • IPV4 Network Mask: 255.255.255.0
DHCP Server Tab:
  • Check "Enable Server"
    HINT: THIS RESOLVES YOUR PROBLEM, BUT OTHERS IS REQUIRED TO AVOID OTHER PROBLEMS
  • Server Address: 192.168.65.100
  • Server Mask: 255.255.255.0
  • Lower Address Bound: 192.168.65.101
  • Higher Address Bound: 192.168.65.255
Note: make sure you don't have any other adapter with the same configuration that might cause conflicts .. revise all of adapters in that section, "Host-Only Networks" I mean, and delete the same ones there.
Good luck
I'm using Ubuntu 14.04 and I got the same error. I reduced the memory below 50% of the total memory. And now it works.
A.B.
  • 92,125
abhishek
I had the same issue. I was normally using my laptop connected to LAN. When I was using the Laptop without LAN(cable disconnected) this error came.
After un-ticking "Cabale Connected" check box in "Network -> Adapter 1", VM stared without any issue.
