I get following error while installing amd graphics drivers-
Please install the required pre-requisites before proceeding with AMD Catalyst installation. Please check file usr/share/ati/fglrx-install.log for more details.
But I cannot locate mthis fglrx-install file.Someone help
Joker
  • 33
The file specified by the installer probably does exist. You can open it with gedit for instance :
gedit /usr/share/ati/fglrx-install.log
Then it will tell you what to install. For me (Ubuntu 15, R9 200 series) it was:
apt-get install dh-modaliases.
apt-get install execstack.
apt-get install debhelper.
Then try again the install driver, with sudo
Rayjax
  • 111
I believe that you need to ensure that you have the Linux headers available. Open a terminal and enter the command
sudo apt-get install linux-headers-generic linux-headers-`uname -r`
You may also need the build esentials, although I don't think they are required for AMD
sudo apt-get install build-essential
I would also strongly recommend that you read this article about removing the AMD drivers before you try the installation.
The log file should be located at /usr/share/ati/fglrx-install.log
Charles Green
  • 21,859
Perhaps your system does not have the following packages:
dh-modaliases and execstack
To install these, type the following commands at terminal (execute terminal by Ctrl + Alt + t)
sudo apt-get install dh-modaliases
sudo apt-get install execstack
OR
sudo apt-get install dh-modaliases execstack
