I have downloaded a bin installation file named "LianjaAppBuilder-1.2.2-linux-x86_64-installer1.bin". I want to run it in terminal but when i type "./LianjaAppBuilder-1.2.2-linux-x86_64-installer1.bin" it says not such file or directory is found. How can I run this file?
Asked
Active
Viewed 785 times
-1
- Check you are in same directory where it downloaded. If not, go to the directory where it downloaded using the
cdcommand. - Give execute permission to the file using the command:
chmod u+x file - Now try to execute
./example-file
If asked for root permission, prefix the command withsudo
karel
- 122,292
- 133
- 301
- 332
Hackaholic
- 99
