41
Is there any way to see WebP photo from Thunar with Xfce DE? There was a similar question, but it was about nautilus.
Then to get WebP thumbnails tumbler (the Xfce thumbnailing service) must support, and there are nothing.
Then to open pictures, the viewer must know WebP.
I tried ristretto, gpicview, viewnior and they all say something like:
error of interpretation of the image file format jpeg
Pablo Bianchi
  • 17,371
Alexander Filёv
  • 573
9 Answers9
37
Here are the Linux image-viewers, that display webp images:
And others, from Wikipedia.
Pablo Bianchi
  • 17,371
Robert Fleming
  • 101
qView
qview
Since 2018, there is a really lightweight and user-friendly image viewer called qView that can view WebP images. It also has a nice feature to resize the window frame to fit the image. It is also free and open source.
You can download the latest version (3.0 at the time of writing, and it's still being actively developed) as a .deb file from the official website or GitHub and install it with gdebi or your software center.
To install from terminal:
sudo add-apt-repository ppa:jurplel/qview
sudo apt update
sudo apt-get --install-suggests install qview
After you install the .deb file, you also need to install this package: Qt 5 Image Formats add-on
sudo apt install qt5-image-formats-plugins
This is because qView is based on Qt5 and even though it supports many common formats by default, it does need this one package to actually view WebP images.
Note: this add-on is pre-installed on Lubuntu and Kubuntu (Qt-based DEs, as expected).
Tested on Ubuntu 18.04, 20.04; Lubuntu 19.10, 20.04.
Pablo Bianchi
  • 17,371
Calico Cat
  • 1,456
10
If you are looking for GUI applications, consider GIMP or ImageMagick.
If you have installed the webp package, you could use vwebp file.webp to view the image, and dwebp file.webp -o file.png to convert it to a png file.
See https://developers.google.com/speed/webp/docs/using for details.
serv-inc
  • 3,159
  • 26
  • 32
wxhhh
  • 101
In 16.04
display 'vid:*.webp'
Since 16.04 imagemagick does support webp, although it apparently delegates decoding to webp, so webp is needed:
sudo apt-get install webp
Janghou
  • 6,035
XNViewMP can view WebP files. Though Tumbler has yet to implement WebP, so the files won't be able to be viewed as thumbnails within Thunar.
Note that it is a non-free software, although freeware.
gThumb also opens/edits webp files. It has some nice must have quick editing tools.
sudo apt-get install gthumb
Version 3.4.3 I know supports webp, but does not support animated webp images.
Developed by Google, WebP is a new image format that provides lossless and lossy compression for images on the web.
You can download a WebP viewer, and other utilities from Google Developers
Mitch
  • 109,787
You can use the stylish looking deepin-image-viewer (from Deepin project, a Linux distro based on China) for WebP.
Pablo Bianchi
  • 17,371
GIMP works well. "Save image as" from the website, navigate to where you saved it, right click "open with", select GIMP and you can then use "File - export as" to export the image from GIMP to your desired destination , remembering to change ".webp" to ".jpg" so that any of your normal programmes will open it.
