After the upgrade to Ubuntu 14.10, my wireless connection has become unstable.
In every 2 to 3 minutes the network stops working (i.e., I am unable to load any page), even though the Network Manager, shows that I am connected.
So I have to manually disconnect it and connect it again,to make it work again, but then again it only works for another 2-3 minutes.
I'm using a Dell Inspiron 7357, with a Intel Corporation Wireless 7260 (rev 73) card. With Ubuntu 14.04, the adapter worked perfectly.
I don't see neither crashes nor errors in dmesg:
$ dmesg | grep iw
[    3.636727] iwlwifi 0000:02:00.0: irq 62 for MSI/MSI-X
[    3.709654] iwlwifi 0000:02:00.0: loaded firmware version 25.222.9.0 op_mode iwlmvm
[    3.742636] iwlwifi 0000:02:00.0: Detected Intel(R) Wireless N 7260, REV=0x144
[    3.743790] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
[    3.744023] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
[    3.940407] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    4.863737] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
[    4.863967] iwlwifi 0000:02:00.0: L1 Enabled; Disabling L0S
Of course, I don't have any problem if I select the old 3.13 kernel in Grub (in that case, the firmware version is the .8). Do you have any ideas?
SamFlynn
  • 1,025
Please try this following workaround:
  1. Open the terminal: Ctrl+Alt+t
  2. sudo modprobe -r iwlwifi
  3. sudo modprobe iwlwifi 11n_disable=1
Case this solved the problem, so...
  1. sudo nano /etc/modprobe.d/iwlwifi.conf
  2. add the line: options iwlwifi 11n_disable=1
  3. Save file
  4. Restart the PC.
Case you have any problem, please comment.
