Is there a way to upgrade Ubuntu from a CD rather than across the network? As it stands now the only thing I know how to do from a CD is a clean install, which wipes everything on the partition.
Yes, the 14.04 .iso now has an "upgrade existing" option. However, it still requires a network connection.
Always backup your files. Also, as far as I know, you will keep all the stuff in your home folder so that includes allot of your settings but you might need to reinstall some of the non standard apps.
I just checked out 14.10 studio and didn't see that option, however, all you have to do is choose "something else". Then, select the Ubuntu partition, select ext4, mount point "/" and DO NOT place a check mark to format the partition. By NOT formating the partition, the installation will not wipe your /home folder.
mchid
  • 44,904
  • 102
  • 162
