I am using Ubuntu 14.04 and 12.04 with the latest updates behind a proxy server at my school. I had no problem a few months ago. However, over the past two months when I try to add a repository with add-apt-repository there is no key retrieved. I can then use sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys KEY with success, but this is annoying. I have created scripts that add PPAs, install software, and more that are now failing because of this issue.
Should I be filing a bug report? If so, could someone please direct me to where to file.
Here is what my terminal output looks like when trying to add the PPA for my-weather-indicator:
$ sudo add-apt-repository ppa:atareao/atareao Applications from atareao More info: https://launchpad.net/~atareao/+archive/ubuntu/atareao Press [ENTER] to continue or ctrl-c to cancel adding it gpg: keyring `/tmp/tmp16ytp9px/secring.gpg' created gpg: keyring `/tmp/tmp16ytp9px/pubring.gpg' created gpg: requesting key 36FD5529 from hkp server keyserver.ubuntu.com gpgkeys: key A3D8A366869FE2DC5FFD79C36A9653F936FD5529 can't be retrieved gpg: no valid OpenPGP data found. gpg: Total number processed: 0 $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 36FD5529 Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.fla11h2USs --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyring /etc/apt/trusted.gpg.d/steam.gpg --keyserver keyserver.ubuntu.com --recv-keys 36FD5529 gpg: requesting key 36FD5529 from hkp server keyserver.ubuntu.com gpg: key 36FD5529: public key "Launchpad PPA for atareao" imported gpg: Total number processed: 1 gpg: imported: 1 (RSA: 1)
Update: I was able to get it working with the -E parameter for sudo, so the command that works is sudo -E add-apt-repository ppa:atareao/atareao. However, I don't understand why things worked without that before and now it does not. Also, this does not seem to explain why other commands with sudo work without the -E parameter. This solution comes from Ubuntu 10.10.
