I am working to restart service if stopped.
I was looking for upstart, to restart service. I found some answers.
I took apache2 service for testing. I changed code as below.
# File : /etc/init.d/apache2
# Function that stops the daemon/service
do_stop()
        # Return
        #   0 if daemon has been stopped
        #   1 if daemon was already stopped
        #   2 if daemon could not be stopped
        #   other if a failure occurred
        # either "stop" or "graceful-stop"
        local STOP=$1
        # can't use pidofproc from LSB here
        local AP_RET=0
        # send stopping apache event
        echo "Stopping....."
        initctl emit stopping-apache2
        if pidof $DAEMON > /dev/null 2>&1 ; then
                if [ -e $PIDFILE ] && pidof $DAEMON | tr ' ' '\n' | grep -w $(cat $PIDFILE) > /dev/null 2>&1 ; then
                        AP_RET=2
                else
                        AP_RET=1
                fi
        else
            AP_RET=0
        fi
        # AP_RET is:
        # 0 if Apache (whichever) is not running
        # 1 if Apache (whichever) is running
        # 2 if Apache from the PIDFILE is running
        if [ $AP_RET = 0 ] ; then
                echo "Stopped.....1"
                initctl emit stopped-apache2
                return 1
        fi
        if [ $AP_RET = 2 ] && apache_conftest ; then
                $APACHE2CTL $STOP > /dev/null 2>&1
                apache_wait_stop $?
                echo "Stopped.....2"
                return $?
        else
                if [ $AP_RET = 2 ]; then
                                        clear_error_msg
                        APACHE2_INIT_MESSAGE="The apache2$DIR_SUFFIX configtest failed, so we are trying to kill it manually. This is almost certainly suboptimal, so please make sure your system is working as you'd expect now!"
                        killproc -p $PIDFILE $DAEMON
                        apache_wait_stop $?
                        echo "Stopped.....3"
                        return $?
                elif [ $AP_RET = 1 ] ; then
                        APACHE2_INIT_MESSAGE="There are processes named 'apache2' running which do not match your pid file which are left untouched in the name of safety, Please review the situation by hand".
                        echo "Stopped.....4"
                        return 2
                fi
        fi
Note: emit message using initctl emit stopped-apache2
Then changed apache2.conf to perform start operation on this event.
# File /etc/init/apache2.conf
# apache2
# the purpose of this job is
# * start apache2 in upstart rather than SysV startup
start on stopped-apache2
stop on runlevel [016]
pre-start script
export RUNLEVEL=2
[ -f /var/lib/apache2.enable ] && /etc/init.d/apache2 start
end script
post-stop exec /etc/init.d/apache2 stop
When I stop apache I got message.
root@localhost:~# /etc/init.d/apache2 stop
[....] Stopping web server: apache2Stopping.....
Stopped.....2
. ok
But seems its not executing start on stopped-apache2.
I also restart job using initctl restart apache2.
I missed something ?
NPatel
  • 143
You can use the Upstart respawn feature. Use the upstart job for apache found here: https://bitbucket.org/CameronNemo/upstart-jobs/src/2090612200fa588412e3fe22aec5ba3747ae88d2/apache2.conf?at=master
then just add a line that reads respawn.
CameronNemo
  • 1,675
