http://paste.ubuntu.com/8732930/
So I have the following setup
1TB Seagate HDD  -sda
1TB Samsung 850 Pro SSD -sdb
I had Three partitions on the HDD
One for OS, another for Games and last for downloads.
After installing the SSD I copied the games and the OS onto the SSD. Deleted these volumes in Windows from the HDD and extended the Download partition onto the whole drive. It worked just fine. For weeks.
Now I freed up 100GB off my SSD to install ubuntu.
I partition those 100GB:
Ext4 - 50 GB root: /
Ext4-  42 GB Root: /home
Swap area: 16GB
I have run the boot repair from USB stick, and after that I now have GRUB as in I can choose which OS to run, but there is only Ubuntu and advanced for ubuntu. No windows 8.1.
I have disabled Fast boot before installing. and in the bios I tried disabling Secure boot, but there was no option for that so I set it from Windows to Other OS.
devGeek
  • 594
I faced out the same issue 2 months ago. These following questions help me so much.
Dual boot Ubuntu and Windows 8 - no operating system found
and
Restore backup of WinEFI or UEFI (not sure) that boot-repair made
Good luck.
So it works now, somehow, I am not 100% sure what was the fix in the end so I am gonna go through everything.
First of all I installed by following the steps here:
http://www.everydaylinuxuser.com/2013/09/install-ubuntu-linux-alongside-windows.html
That included boot-repair etc.
" So, let's try reinstall the grub-efi sudo apt-get install --reinstall grub-efi; sudo > update-grub – Marcos Rocha 3 hours ago " – Marcos Rocha 3 hours ago
After trying that I got to the state where I had two options to boot into windows, One was using my HDD which makes no sense as there is nothing installed there anymore but whatever probably a relic left behind from HDD cloning to SSD.
1. Create a Win764bit usb
2. Boot onto USB
3. Run startup repair
4. -> AFter restart it still didn't work I updated grub2 with something like :
sudo apt-get reinstall grub2
sudo update-grub2
IRRELEVANT FROM HERE
Then in BIOS of my ASUS H87M-E
I set back the boot option to WINDOWS from OTHER OS.
One of these solved it.
Edit: Went ahead and switched it back from WINDOWS UEFI mode to Other OS.
Still works.
