I was on Ubuntu 14.04 yesterday, and upgrade with do-release-upgrade. Today, Skype isn't installed anymore.
Here is the error I get when installing through the .deb:
$ sudo dpkg -i skype-ubuntu-precise_4.3.0.37-1_i386.deb
Selecting previously unselected package skype.
(Reading database ... 446199 files and directories currently installed.)
Preparing to unpack skype-ubuntu-precise_4.3.0.37-1_i386.deb ...
Unpacking skype (4.3.0.37-1) ...
dpkg: dependency problems prevent configuration of skype:
 skype depends on libqtwebkit4 (>= 2.2~2011week36); however:
  Package libqtwebkit4:i386 is not installed.
 skype depends on libpulse0; however:
  Package libpulse0:i386 is not installed.
 skype depends on libasound2-plugins; however:
dpkg: error processing package skype (--install):
 dependency problems - leaving unconfigured
Processing triggers for hicolor-icon-theme (0.13-1) ...
Processing triggers for bamfdaemon (0.5.1+14.10.20140925-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils (0.22-1ubuntu2) ...
Processing triggers for mime-support (3.55ubuntu1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for dbus (1.8.8-1ubuntu2) ...
 skype
And if I try to use the partner repo:
$ sudo apt-get install skype
Reading package lists... Done
Building dependency tree
 skype : Depends: skype-bin
If I sudo apt-get -f install and try to reinstall the .deb, I end up with this error:
skype: error while loading shared libraries: libQtWebKit.so.4
So, after purging everything, as @Jan suggested, the following still didn't work:
I had the following error:
Turns out I needed the following:
sudo apt-get install skype skype-bin
And everything worked out of the box.
I have no idea why.
I assue that after trying to install from the .deb, you had a half-installed package lingering. To get rid of everything skype-related, use sudo apt-get purge skype in a terminal window (or if that fails, use dpkg -P skype).
Installing from the partner repo should work then.
Jan
  • 12,931
  • 34
  • 39
