When I installed Virtual box it would not run a machine. Same problem as encountered previously of it missing vboxdrv. Old fixes didnt work.
VMWare won't install as kernel headers do not match.
Can anyone help~? Thanks
The kernel in use is 13.13.0-37, but should be 13.16 for Utopic.
My suggestion for attempting to fix this would be as follows:
Backup important data...
Remove the Nvidia drivers, as they may be a problem when upgrading kernels. They can be reinstalled after kernel upgrade
Attempt to do a distribution upgrade: sudo apt-get update && sudo apt-get dist-upgrade
reboot
Check to see if the kernel has been update uname -r - kernel should be 3.16.0-24
Reinstall Nvidia drivers if desired
Reinstall VMWare
Thank's to Charles Greens's answer, Next time when I installed VMware Player I followed this:
VMware Player 7.0.0 Installation
First of all, run the following command:
sudo apt-get install build-essential linux-headers-`uname -r`
To install VMware Player 7.0.0 under Ubuntu 14.10 or older, run simply these commands from the Terminal:
mkdir ~/VMware && cd ~/VMware
wget -c http://goo.gl/A9LHQv -O VMware-Player-7.0.0.x86_64.bundle.tar
tar -xvf VMware-Player-7.0.0.x86_64.bundle.tar
chmod +x VMware-Player-7.0.0-2305329.x86_64.bundle
sudo sh VMware-Player-7.0.0-2305329.x86_64.bundle
Source: http://dothisbest.com/how-to/install-vmware-player-7-0-0-on-ubuntu-14-10/
I fixed the problem by uninstalling the virtualbox installed in software center. Then install the deb package from official site.
