Is it possible to email attachments from the command line?
If possible, I'd like something as simple as:
mail -a myfile.txt -t me@example.com -s "Here's my file"
Of all the mail user agents in the Ubuntu repository, it appears that mutt is the command-line MUA that is blessed with Long Term Support.
According to the manual, you can do something exactly like:
mutt -a myfile.txt -s "Here's my file" -- me@example.com
except it won't go anywhere since one also needs a Mail Transfer Agent. Popular ones are:
and the only ones that Canonical seems to support are postfix (thanks for the correction Steve) and exim4.
One could also say that xdg-email is also a proper Ubuntu MUA, but it is a bare-bones front end which only executes your preferred MUA on your behalf.
If you'd like advice on which MTA might be suitable for your use, perhaps open another question here.
I had bad trouble with sending attachment files, too. When I sent an email without attachment, it was successful but was not with attachment. This problem was existent with sendemail, mutt, mail, mailx , uuencode commands.
Fortunately, It was solved funnily. I use Gmail for sending email. You can configure your gmail for sending emails via commands in terminal as declared at http://www.linuxandlife.com/2013/01/send-email-from-linux-terminal.html .
You can send a text email using:
mail -s "hello" RECEIVE@mail.com < /home/masoud/YOURFILE.txt
but you can't send same file as attachment as below:
mail -s "hello" RECEIVE@mail.com -a /home/masoud/YOURFILE.txt
or:
mail -s "hello" -a /home/masoud/YOURFILE.txt RECEIVE@mail.com
Finally, I understood that only this format could send an attachment:
echo "your message here" | mail -s "title" -a /home/masoud/YOURFILE.txt RECEIVE@mail.com
Funnily, the difference is existence of the "echo" command.
Seems that the -a option has been changed with Uppercase -A for attachment now. The -a seems to be for changing header according to doc
I found that the command and parameters have been changed recently.
If your want to send your attachments with this command:
mail -s "your subject" you@gmail.com -A /your/attachment/absolute/path < /home/you/message.txt
The option attachment should be -A which is CAPITAL A.
You may want to send a file from the shell, but otherwise use Thunderbird.
In this case, try thunderbird -remote ... is useful - assuming thunderbird is usually running:
The command opens a mail compose window of a running thunderbird instance.
The "From" address is your default address configured in thunderbird.
Also, the existing account settings are used, there is no separate setup needed.
For a mail adressed to you@example.com, with subject "S", body "B", and an attachment /some/absolute/file.txt, the command is
thunderbird -remote "xfeDoCommand(composeMessage,subject='S',to='you@example.com',body='B',attachment='/some/absolute/file.txt')"
There are two problems:
The attached file needs to be given by an absolute path, which is tedious in practice. That can be handeled by using readlink -f to resolve relative paths:
thunderbird -remote "xfeDoCommand(composeMessage,subject='S',to='you@example.com',body='B',attachment='$(readlink -f file.txt)')"
Also, the command is to long. Use a shell script or shell function, with four arguments:
thunderbird-compose () {
thunderbird -remote "xfeDoCommand(composeMessage,subject='$1',to='$2',body='$3',attachment='$(readlink -f $4)')"
With this function, the command becomes readable:
thunderbird-compose 'Some Subject' test@example.com 'Body of message' file1
will open a thunderbird "Write" window with the attachment, and From, To, Subject, and body text filled in. It can be edited before sending it.
heirloom-mailx package in debian provides mailx command to send mime attachments easily. following works for me;
mailx -a attachment.zip -s subject rctp@domain.to
My version of mail, BSD mail, does not seem to support attachments (it's not mentioned anywhere in the manpage).
A hacky workaround is to send the attachment as uuencoded stream. Gmail will interpret this as two attachments, one called "noname" which is the uuencoded text and the other called "-" which carries the decoded version that can be opened by any program that recognizes the file type by its binary data. I don't know if this behavior is documented or applies for any other mail client, but if you don't want to install anything this is a quick hack.
uuencode image.jpg - | mail -s "Subject line" user@example.net
I wish to add another answer which is used to add body text along with the attachment. Cheers!!
echo "This is the message body" | mutt -a "/path/to/file.to.attach" -s "subject of message" -- recipient@domain.com
