I am new to BASH and learnt that both printf and echo write to the standard output. But, I came through the following example which reads an expression from input and computes the result to accuracy of 3 decimal places:
read exp
printf "%.3f\n" "$(echo $exp | bc -l)"
I don't get why echo is passed here as an argument in the the printf statement. Is there any other way to represent the statement using only echo?
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
coder_r
  • 53
After read exp, you can use echo as follow:
$ echo "scale=3; $exp/1" | bc
9.456
But note that this command does not require echo:
$ bc <<< "scale=3; $exp/1"
9.456
EDIT: in order to get a rounded result you have to use the printf bash builtin as bc can't round values.
The following command works as expected:
 echo "scale=4; $exp" | bc | xargs printf "%.3f\n"
Here is a solution using only echo:
  • if you are using a decimal point (.) in your rational number:
    $ read exp
    123.4567
    $ int=${exp%%.*}
    $ rat=${exp##*.}
    $ echo $int.${rat:0:3}
    123.456
  • if you are using a decimal comma (,) in your rational number (as I use and most part of continental Europe):
    $ read exp
    123,4567
    $ int=${exp%%,*}
    $ rat=${exp##*,}
    $ echo $int,${rat:0:3}
    123,456
For more info see Advanced Bash-Scripting Guide: Manipulating Strings.
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
