I am trying to use Brasero, to burn a mkv file of 300mb size to a blank CD and it nags that cd has not enough disk, I used mkvmerge to break it to 4 100 mb files it still nags that it cant burn it due to size, anyone knows how may I do it?
Max
  • 422
Have you tried using devede it may work better than Brasero as its main purpose is to create dvd's and vcd also I would run Brasero from terminal and see what messages are output to terminal.
Finally the max length of a VCD is going to be 80min if you convert the mkv to a "playable" vcd if you are just writing the mkv to the disk as a "data" disk then there should be no problem.
Allan
  • 11,672
ImgBurn of Windows works in Wine. Use the last version of the program
